mcervinojr
Apr 02, 2017Aspirant
Nighthawk or Orbi
Hi all, Looking for advice on a Network setup for our new summer home. The house is 3 levels, approximately 1,200 SF each level. First floor has kitchen, living room, 3 bedrooms. Second floor...
mcervinojr
Comcast Cable
- st_shawApr 02, 2017Master
The Ubiquiti APs work great. I have them and would buy them again. If the main use of your network is running benchmarks, or you demand the fastest throughput on the market, then you need to buy the new $350 AP-AC-HD APs. Otherwise the AP-AC-PROs work very well.
- peteytestingApr 02, 2017Hero
mcervinojr wrote:
Comcast Cableso is the cable modem also a router or is it a pure modem or bridged
if its pure modem or bridged what would you be using as the router
is the cable modem located in the same place the ethernet cables are all running back to ?
