NetMan62
Apr 13, 2019Aspirant
Nighthawk R700 AC1900 with Orbi RBR50 - best setup?
(Note - you cannot select AC3000 Orbi - it is not in the list for MODEL)
I bought the RBR50, unplugged my router, and set it up and tested...pretty simple, web interface same as AC1900. Using t...
NetMan62
PS my only reason to upgrade would be to bond two ethernet ports on the switch into a new router like the X66 or AX8 for link aggregation, unsure if there is any other reason to upgrade.....unless I went off Orbi and use dhe X4/X6/X6S plugin mesh connectors?
