NetMan62
Apr 13, 2019Aspirant
Nighthawk R700 AC1900 with Orbi RBR50 - best setup?
(Note - you cannot select AC3000 Orbi - it is not in the list for MODEL)
I bought the RBR50, unplugged my router, and set it up and tested...pretty simple, web interface same as AC1900. Using t...
michaelkenward
Apr 14, 2019Guru - Experienced User
That's because it isn't a model (see below). The model is the RBR50 bit.
In various places you refer to R700, R7000, AC1900 and A7000.
My guess is that you mean the R7000, which is a router model that supports AC1900, which is not a model number but a label that Netgear, and others, attach to hardware to describe wifi speeds.
NetMan62 wrote:
Wondering if I should just keep the Nighthawk AC1900 with FiFi disabled, add on the Orbi in Access Point Mode for best overall network?
That should work. A lot of people run Orbis in AP mode.
What settings would I need to make to the R7000 besides disabling WiFi?
You don't even need to disable the wifi on the R7000. But if you have no need for the wifi, or if it causes issues, then by all means turn it off.
NetMan62
Apr 14, 2019Aspirant
Correct..r7000 night hawk ac1900 router. So I have the orbi rbr50 ac3000 now in AP mode working fine. However, WiFi on r7000 is disabled, as you don't want to use same said as the orbi.... The r7000 and orbi ac3000 don't act as one mesh network, pretty other notes on here.
Still wondering if I should just upgrade the R7000 to a Triband router or AX wifi6 router, versus adding on orbi. TVs,PC and Tivo hardwired, just a few phones, tablet and two laptops on AC WiFi (phones support wifi6) .
Thank you for the advice.
- michaelkenwardApr 14, 2019Guru - Experienced User
NetMan62 wrote:
Still wondering if I should just upgrade the R7000 to a Triband router or AX wifi6 router, versus adding on orbi. TVs,PC and Tivo hardwired, just a few phones, tablet and two laptops on AC WiFi (phones support wifi6) .Do you have any problems with the wifi on the phones, tablet and laptops?
If your Internet speed is the limiting factor, "faster" routers will not do much.
- NetMan62Apr 15, 2019Aspirant
Was looking for better performance on the router ie processing capability especially since my TIVO and tvs are wired, port aggregation, etc. For WiFi would like the same wireless speeds as my internet connection - so looking for 300 mbs speeds, to match ISP speed. Have 2 samsung s10 phones, both have wifi6 with mu-mimo capability.
- FURRYe38Apr 15, 2019Guru - Experienced User
To take advantage of WiFi 6, you may want to upgrade both R7000 and Orbi for a RAX router.
Orbi is coming out with WiFi 6 systems I believe later on this year or next. Current Orbi systems will NOT see any WiFi 6 as this is a hardware change.
