Pete58
Dec 31, 2021Follower
Nighthawk WiFi wont pass HD homerun TV IP
I have been using a Linksys XAC 1900 Wifi, Router / Modem without issue for some years to among other things distribute IP TV from a HD Homerun Connect (model - HDHR4-2DT). I have previously used th...
CrimpOn
Dec 31, 2021Guru - Experienced User
By keeping the Linksys router, you have created two entirely separate networks:
- Everything connected to the Linksys is on one network (including the WAN port of the Nighthawk)
- Everything connected to the Nighthawk is on an entirely different network, which is hidden behind Network Address Translation (NAT).
If the Linksys router must be kept, then the NIghthawk could be put into access point (AP) mode, which will result in one network administered by the Linksys. All devices should be able to connect to every other device.
