Andie6931's avatar
Andie6931
Nighthawk X8 + Orbi RBK53 how to set up AP mode ?
I need a detailed instruction to set up my new Orbi system as a mesh network and keep my nighthawk as the base router.
Can somebody describe this to me as detailed as possible please ?
Thanks
    • Andie6931's avatar
      Andie6931
      That worked well Stephen. All is up and running.
      Just one point is open: can I use the same WiFi Id and password for nighthawk x8 + Orbi unit ? And how to I sync them?
      Thanks a lot in advance.
      • StephenB's avatar
        You can (manually matching the name/passphrase), but the X8 and the Orbi will be running independently.  Your client devices will choose to join which ever network they want.
        If it causes a performance problem you might need to keep the names/passphrases separate.
