Einstein1's avatar
Einstein1
Follower
Feb 28, 2017
Nighthawk X8 + orbi?
Guys, I have a very big place and right now Im using apple airports, 4, to trying to get good wifi coverage. Im not happy.
I bought a nighthawk x8 but coverage is not as good as 4 airports. So now Im thinking to use Orbi. Any recomendations?
Thanks
1 Reply
    Thanks
    sure the orbi system should work fine as long as you can locate the orbi router in the center of the house and a sat towards each end , the orbi system is star topology and not mesh so all sats connect back to the orbi router and placement is the key
