Orbiconfuser33
Jun 11, 2018Follower
Nintendo 3DS won’t connect to Satellite
So I’m able to connect the DS to the router when I’m on the first floor, within the range of the router. The issue I’m having is that the DS won’t reliably connect to the satellite. It will connect so...
Jun 12, 2018Guru - Experienced User
What wifi channels are you using? Try manual 1, 6 or 11 on 2.4Ghz.
What wifi security modes are you using?
Try disabling Daisy Chain, MIMO and Fast Roaming on the router.
What is the distance between the router and satellite? Feet?
