JanMoelbach
Apr 30, 2017Follower
No color on satellite on startup - dead unit?
Hi, I just bought this system. The router works well, but I just can't seem to get anything working on the satellite. When I power it on, the power LED turns green, and then nothing happens. The "...
DarrenM
May 01, 2017Sr. NETGEAR Moderator
Hello JanMielbach
Yea you might want to swap the unit if possible if not contact Netgear support.
http://www.netgear.com/support/contact.aspx
DarrenM
