brvidorbi
Sep 22, 2018Aspirant
No colors on top rings of NETGEAR Orbi Home Mesh WiFi System (RBK50)
I've set up my (RBK50) and its providing the appropriate speedy internet connectivity to my wired and wireless devices. The only issue is that I'm not seeing any colors from the rings on the top of ...
quagmire1
Sep 22, 2018Luminary
The Ring LEDs being off indicates normal operation.
Unlike routers of old, the Orbi is supposed to be discreet, so no flashing or bright lights except during setup or if there is an issue.
There is a small LED power light on the back which should be green.
See:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
brvidorbi
Sep 23, 2018Aspirant
OK that makes sense, but, should either the router or satellite lite blue for a few seconds during the initial set up?
