brvidorbi
Sep 22, 2018Aspirant
No colors on top rings of NETGEAR Orbi Home Mesh WiFi System (RBK50)
I've set up my (RBK50) and its providing the appropriate speedy internet connectivity to my wired and wireless devices. The only issue is that I'm not seeing any colors from the rings on the top of ...
Sep 24, 2018Guru - Experienced User
What FW is currently loaded?
If the BLUE led doesn't turn on on the router for a few seconds, could just mean that the connection between the router and modem was good and the router has a good connection and didn't have to turn on the top LED. I've noticed that in recent versions of FW. White, then Pink then no BLUE led. Internet connection is good. Nothing to be worried about. You should see BLUE on top of the satellites when setting them up however.
brvidorbi wrote:
I've set up my (RBK50) and its providing the appropriate speedy internet connectivity to my wired and wireless devices. The only issue is that I'm not seeing any colors from the rings on the top of the router and satellite. When setting them up they were white for a few moments but now that the system is configured and operating the rings don't illuminate at all. And I never saw blue on top of either of them, only white when setting them up. Am I misunderstanding how they are meant to operate? I thought the colors where supposed to illuminate to confirm operation and show you strong signal strenth via blue light. I've checked the speed via various internet speed tests and it seems correct. It's a minor concern but am I not supposed to be seeing the colors illuminating at the top of the units? Any clarificaiton would be appreciated. Thanks.
