ChrisCox1952
May 08, 2022Guide
No connection with internet at start to conninterne( needs 5+ seconds) once connected speed is 100%
I am having Orbi RB50 VS 2 system and generally it works perfect My only issue is that if i start a connection to Internet, first i am getting warfning/message that there is no connection, then i ha...
- May 09, 2022
Most Ziggo boxes are modem/router combo devices and cause a doubt nat (but can't 100% confirm without an actual model)
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
May 08, 2022Guru - Experienced User
1. what modem/gateway is it connected to?
2. what firmware is on the orbi router? And on the satellites?
3. You're only getting the notice on your windows pc's?
4. what happens if you disable norton?
ChrisCox1952
May 09, 2022Guide
Good morning Plemans
Following to your answers
1. I am using Ziggo ISP, therefore the connectbox from Ziggo
2. Firmware on Orbi router 2.7.3.22
3. I am getting message on PC, not sure about Iphone and/or Ipad ( soory for not being more specicily)
4. I didnot try to disable norton so far
hope this helps
regards
Chris
- plemansMay 09, 2022Guru - Experienced User
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode- ChrisCox1952May 10, 2022Guide
Hi Plemans
i checked with ISP, and they confirmed that I do have bridge mode setup on their router. What has happened they informed me that some time ago a firmware updated was done to modem. Modem has been reset by them, and I am now seeing if that will solve issue,
thanks for your support
regards
Chris
- plemansMay 10, 2022Guru - Experienced User
I hope that fixes it for you!
If not, try putting the ziggo back in router mode (disable its wifi) and then put the netgears address into its dmz.
I've seen to many isp supplied devices not function properly in bridge/passthrough mode.
