ChrisCox1952
May 08, 2022Guide
No connection with internet at start to conninterne( needs 5+ seconds) once connected speed is 100%
I am having Orbi RB50 VS 2 system and generally it works perfect My only issue is that if i start a connection to Internet, first i am getting warfning/message that there is no connection, then i ha...
- May 09, 2022
Most Ziggo boxes are modem/router combo devices and cause a doubt nat (but can't 100% confirm without an actual model)
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
ChrisCox1952
May 09, 2022Guide
Good morning Plemans
Following to your answers
1. I am using Ziggo ISP, therefore the connectbox from Ziggo
2. Firmware on Orbi router 2.7.3.22
3. I am getting message on PC, not sure about Iphone and/or Ipad ( soory for not being more specicily)
4. I didnot try to disable norton so far
hope this helps
regards
Chris
May 09, 2022Guru - Experienced User
