JulesDuf
Sep 05, 2020Aspirant
no connections to satelite
Hi, I bought an Orbi RBR50 and a satelite a bit more than a year ago ; initially everything went fine, but now I just can't connect properly any device to the satelite. Either my devices (phone,...
Mstrbig
Sep 05, 2020Master
JulesDuf wrote:The satelite is RBS50, the firmware is 2.5.1.16. The satelite is about 10 m from the router at the entrance of another room, where the wifi signal is still OK. Happy to try another channel but I don't know how to do that. thanks !
Orbilogin.com Wireless tab, 2.4Ghzx and 5Ghz channel.
You can use NetSpot to see what your neighbors are using and pick a less used channel.
JulesDuf
Sep 06, 2020Aspirant
thanks for your answer. I changed the channels, and it partly works, now the satelite is detected and the devices can connect either to the main router or the satelite. The problem is that every couple of minutes some of the devices, when connected to the satelite, can't get access to internet (the status on the device is "connected, internet may not be available" while some other devices work OK.
I feel like I am going to continue to face issues
- MstrbigSep 07, 2020Master
How far are the satellites from the router and other satellites?
- JulesDufSep 07, 2020Aspirant
about 10 meters away, the satelite is at the entrance of a room, where the signal is still decent but when we go in the middle of the room the signal with only the router is not good enough.
the connections issues usually appear when we are close to the satelite, but what's really annoying is that it used to worked OK for a while and then suddenly we started to have all these issues. Last time I reinstalled everything and then it worked for a couple of months but this time it does not work even after multipe reinstalls
Not sure if I asked, if satellites are wireless, is Daisy-Chain Topology checked or unchecked? On depends on how you have your satellites placed. If the furthest satellite relys on the middles satellite, it should be checked.
