varun8211
Dec 28, 2019Follower
No devices connected to the Satellite
I have Orbi model # - RBR40. I have 2 satellites connected. But none of my devices connect to them. They always stay connected with the main router. Shouldn't my devices automatically connect to t...
SW_
Dec 29, 2019Prodigy
It's often the case when there's strong signal overlapping/interference within the same area of coverage. A simple solution is to reboot/power cyle the device in question. If the device is running into trouble because of weak signal and won't connect to nearby Satellite after reboot, you can check out this workaround.
