fsa317
Nov 21, 2020Aspirant
No devices connecting to satellite
Been trying to improve my setup. I had my Orbi in my basement but moved it to a new setup that is like this. In my basement's "back room" is my fios router. Hardwired from there is an 8 port sw...
Nov 21, 2020Guru - Experienced User
Be sure the RBS are connected behind the RBR:
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
- fsa317Nov 21, 2020Aspirant
The switch is this one:
https://www.amazon.com/gp/product/B00KFD0SYK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
What do you mean by behind? Right now its basically router --> swtich and then the switch has hardwired connections to both the RBR40 and RBS.
- FURRYe38Nov 21, 2020Guru - Experienced User
ALL ethernet RBS connection have to be connected at the RBR, not at the main host router or ISP modem/router.
Review the link on where the RBS are connected...
- fsa317Nov 22, 2020Aspirant
Ok, that at least explains what is going on. The challenge I have is that when the RBR was in my basement and i used its ethernet ports "behind" the switch devices would try to wirelessly connect to it with a weak signal (since it was in a back room in the basement). I'm thinking my best bet may be to NOT try to have the RBS wired.
