fsa317
Nov 21, 2020Aspirant
No devices connecting to satellite
Been trying to improve my setup. I had my Orbi in my basement but moved it to a new setup that is like this. In my basement's "back room" is my fios router. Hardwired from there is an 8 port sw...
fsa317
The switch is this one:
https://www.amazon.com/gp/product/B00KFD0SYK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
What do you mean by behind? Right now its basically router --> swtich and then the switch has hardwired connections to both the RBR40 and RBS.
Nov 21, 2020Guru - Experienced User
ALL ethernet RBS connection have to be connected at the RBR, not at the main host router or ISP modem/router.
Review the link on where the RBS are connected...
- fsa317Nov 22, 2020Aspirant
Ok, that at least explains what is going on. The challenge I have is that when the RBR was in my basement and i used its ethernet ports "behind" the switch devices would try to wirelessly connect to it with a weak signal (since it was in a back room in the basement). I'm thinking my best bet may be to NOT try to have the RBS wired.
- FURRYe38Nov 22, 2020Guru - Experienced User
ALso its not recommended to have wifi routers in the basement as well. All that concrete and steel inhibits good wifi signal travel.
Also seems like a LAN wire configuration issue for RBS as well.
