insp
Sep 14, 2020Aspirant
No DHCP function
I set up the ORBI53 in AP mode. Almost everything is ok. My subnet is 10.1.0.0. A router with DHCP service is running on 10.1.0.1. The AP (router has 10.1.0.2) Ap1 10.1.0.3 Ap2 10.1.0.3 assigned by t...
CrimpOn
Sep 14, 2020Guru - Experienced User
insp wrote:I set up the ORBI53 in AP mode. Almost everything is ok. My subnet is 10.1.0.0. A router with DHCP service is running on 10.1.0.1. The AP (router has 10.1.0.2) Ap1 10.1.0.3 Ap2 10.1.0.3 assigned by the main router to 10.1.0.1. Each Ap has a LAN connection. When I connect a PC to the Ap via cable, it gets a DHCP address (the Ap is now just a switch). If I go to the same Ap1 with WiFi a connection is possible but the part does not get an AP! Why is the question. If I give the PC a fixed IP and DNS and gateway, everything works perfectly. Die FW is actuell
Is that a typing error? (AP1 with same IP address as AP2 -- 10.0.0.3 for both of them?)
Are any other devices connected to the Orbi WiFi?
