mrputtputt
May 02, 2018Tutor
No easy way to turn off router and satelitte wifi
Model - RBR50
Firmware - V2.1.4.10
App version - 2.1.2.313 (for mobile), else using IP# thru Windows 10 laptop
OS - windows 10 PC
How to I turn off the router's wifi and the satellite's w...
May 02, 2018Guru - Experienced User
You can disable the wireless radios on the router under Advanced/Advanced Settings/Wireless.
Uncheck Enable SSID Broadcast. NOt sure if the Satellite can be done the same way. The satellite may have wifi always on.
