mrputtputt
May 03, 2018Tutor
No easy way to turn off router and satelitte wifi
Model - RBR50
Firmware - V2.1.4.10
App version - 2.1.2.313 (for mobile), else using IP# thru Windows 10 laptop
OS - windows 10 PC
How to I turn off the router's wifi and the satellite's w...
st_shaw
May 03, 2018Master
You can't turn off WIFi via the GUI. There is a post on here describing how to temporarily disable a client radio via telnet, but I don't think the setting will persist after a reboot.
If you don't want to use Wifi, then I don't think you need an Orbi. Just buy a gigabit switch to replace the satellite and add a cheap router.
mrputtputt
May 07, 2018Tutor
that is true. but it was already purchased to get a new router and replace a really old one.
In hindsight, should've just bought a nighthawk. But part on sale and part paid with gift cards.
