vortech
Jul 28, 2022Follower
No Ethernet Cable Is Plugged into the Orbi Router Internet Port
After reading this thread I got pretty worried when I was running into the same problem. However doing a factory reset on the router saw the problem go away. Restoring my settings from a back up file...
Jul 29, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
