schmurnan
Mar 21, 2023Aspirant
No ethernet connectivity from RBR50 (backhaul or devices)
I think I may have a similar issue as posted here (https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/Orbi-RBR50-No-connection-to-ethernet-wired-devices/m-p/2096775#M120756). Everythi...
- Mar 22, 2023
I've fixed it.
I would never have known this was even a 'thing', but the unmanaged switch in my lounge - between the router and the switch into my dining room - was the culprit.
I narrowed it down to the switch, so I unplugged it and tried it elsewhere in the chain and it worked without issue, which made me doubt whether that was the issue after all. I then positioned back in its original spot, plugged it in and all of a sudden, it's working without issue. I systematically plugged everything back into it, and everything is now purring like a kitten.
I did not realise that simply power cycling a dumb switch could fix the problem (given that there are no 'brains' going on in there) nor would I have thought that that could cause the issue in the first place... how has it managed to cause an issue in the network when all it's doing it providing more ports in the network?
In answer to your latest question though, FURRYe38, so as not to be rude when you've been helping me out...
The switch in question is a Netgear GS316-100UKS 16-port Gigabit unmanaged switch. Cables are mainly Cat.5e given that Cat.6 were too thick to manoeuvre around where required (i.e. when not in a straight run). My broadband is only 45 Mbps so I'm not suffering by using Cat.5e, although ultimately I would like to move to Cat.6 as a minimum, but that's a MAJOR job involving running cables through walls (I live in a brick house) and around bends and doorways.
Mar 21, 2023Guru - Experienced User
Does the top ring LED turn on PINK when this happens?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
The other linked thread ended up being a bad LAN cable connector on a LAN device.
- schmurnanMar 21, 2023Aspirant
I've had various different colours throughout this process.
I've had white when it's restarting; blue on the satellites when they're syncing; and pink on the router when it's trying to establish a connection or obtain an IP address.
I've had the pink light a few times in the past - normally after a firmware update or when something somewhere has gone wrong and it's lost connectivity - sometimes get drops in connectivity through the night according to the HomeKit notifications on my phone most mornings ("All home hubs are not responding").
At the moment I don't have any lights on anything - all Wi-Fi devices are working perfectly; all ethernet devices are not.
I've powered off the router and the modem several times for one minute minimum each time, and have performed the sequential reboot of devices several times to no avail.
RBR50 is running firmware v2.7.5.4, RBS50s are running v2.7.4.24 (and continuously tell me there are no further firmware upgrades available).
CAT.6 between the modem and router (right next to each other).
So as painful as it may end up being, I think I may be at the stage of systematically cable testing every cable in my setup and trying to isolate the offending device.
- FURRYe38Mar 21, 2023Guru - Experienced User
Yes I would check ethernet cabling for all wired devices to see whats going on. Disconnect ALL ethernet cables from the back of the RBR and just connect one wired PC or laptop and test.
You need to update the RBS as well to same version of FW manually using a wired PC and web browser and send the FW file package to the RBS web page:
I tried connecting directly to the RBR50 via ethernet this morning but my Mac was getting a 169.x.x.x address as well, so wasn't able to. So I'll have to try and find the rogue device/cable unfortunately.
FURRYe38 wrote:Yes I would check ethernet cabling for all wired devices to see whats going on. Disconnect ALL ethernet cables from the back of the RBR and just connect one wired PC or laptop and test.
Yes I have tried to manually update it (twice) - the first time it went through the process but didn't update the version number; the second time it told me I was trying to update to a version that's already installed (even though the file I have is RBS50-V2.7.5.4.img.
