schmurnan
Mar 21, 2023Aspirant
No ethernet connectivity from RBR50 (backhaul or devices)
I think I may have a similar issue as posted here (https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/Orbi-RBR50-No-connection-to-ethernet-wired-devices/m-p/2096775#M120756). Everythi...
- Mar 22, 2023
I've fixed it.
I would never have known this was even a 'thing', but the unmanaged switch in my lounge - between the router and the switch into my dining room - was the culprit.
I narrowed it down to the switch, so I unplugged it and tried it elsewhere in the chain and it worked without issue, which made me doubt whether that was the issue after all. I then positioned back in its original spot, plugged it in and all of a sudden, it's working without issue. I systematically plugged everything back into it, and everything is now purring like a kitten.
I did not realise that simply power cycling a dumb switch could fix the problem (given that there are no 'brains' going on in there) nor would I have thought that that could cause the issue in the first place... how has it managed to cause an issue in the network when all it's doing it providing more ports in the network?
In answer to your latest question though, FURRYe38, so as not to be rude when you've been helping me out...
The switch in question is a Netgear GS316-100UKS 16-port Gigabit unmanaged switch. Cables are mainly Cat.5e given that Cat.6 were too thick to manoeuvre around where required (i.e. when not in a straight run). My broadband is only 45 Mbps so I'm not suffering by using Cat.5e, although ultimately I would like to move to Cat.6 as a minimum, but that's a MAJOR job involving running cables through walls (I live in a brick house) and around bends and doorways.
Mar 21, 2023Guru - Experienced User
Yes I would check ethernet cabling for all wired devices to see whats going on. Disconnect ALL ethernet cables from the back of the RBR and just connect one wired PC or laptop and test.
You need to update the RBS as well to same version of FW manually using a wired PC and web browser and send the FW file package to the RBS web page:
schmurnan
I tried connecting directly to the RBR50 via ethernet this morning but my Mac was getting a 169.x.x.x address as well, so wasn't able to. So I'll have to try and find the rogue device/cable unfortunately.
FURRYe38 wrote:Yes I would check ethernet cabling for all wired devices to see whats going on. Disconnect ALL ethernet cables from the back of the RBR and just connect one wired PC or laptop and test.
Yes I have tried to manually update it (twice) - the first time it went through the process but didn't update the version number; the second time it told me I was trying to update to a version that's already installed (even though the file I have is RBS50-V2.7.5.4.img.
- schmurnanMar 21, 2023Aspirant
I feel like I'm starting to exhaust my options somewhat.
The devices that were connecting to 16.x.x.x addresses stopped after I turned off the satellites and they reconnected to the router (apart from my Eve Indoor Camera, which for now I've disconnected entirely). I've systematically tested every cable between my router and Satellite 1 and there are zero issues with any cables. Devices, on the other hand, I don't know, there could be issues that I haven't found. But I'm working on the assumption at the moment that a cable is the more likely culprit than a device (most of which are pretty new) just randomly deciding to break for no apparent reason.
I've now managed to upgrade the firmware on the two RBS50s, so all devices are now in sync in terms of firmware.
When I power cycle the router and disconnect both satellites, and then I connect a switch to the back of the router (which has my Philips Hue bridge and IKEA Tradfri gateway connected to it) everything is fine - the lights are controllable via HomeKit, the Hue and IKEA apps work perfectly. As soon as I connect Satellite 1 and the cables in the back of it, I start getting issues - Hue hub external connectivity light goes out, IKEA app won't connect to the gateway. Satellite 1 still only shows connectivity via 5G (even though I've synced the satellite to the router and all cables are plugged in).
I've just turned on satellite 2, and it's currently connecting via 5G (no ethernet connected yet). But I assume the same behaviour will happen after I sync the satellite to the router.
I really don't understand what the problem is all of a sudden - this has been rock solid for a few years now.
My gut at the moment says there's a faulty port somewhere between the router and Satellite 1, but without systematically trying every device (of which there are 12 and I've already ruled out seven) I don't know how to prove it.
I've now had this issue for over 24 hours, and I've spent 17.5 of those trying to fix this with what feels like zero progress.
UPDATE: I've narrowed it down to something connected between the router and Satellite 1. Everything else in the house is now up and running, including Satellite 2 which has re-established connectivity via ethernet backhaul to the router, which means I can at least go to work tomorrow as all my office equipment is back online.
Satellite 1 is connected to the router via a series of switches:
Router -> Lounge switch (unmanaged) -> Dining room switch (unmanaged) -> Satellite 1
- [Lounge] TV
- [Lounge] Apple TV
- [Lounge] PS5
- [Lounge] Xbox
- [Lounge] Sky Q
- [Lounge] Sonos
- [Lounge] ethernet to dining room switch
- [Dining room] TV
- [Dining room] Apple TV
- [Dining room] Sky Q mini
- [Dining room] Sonos
- [Dining room] Satellite 1
I've tested all cables in the lounge, and I've tested the cables from the router to the lounge switch, the lounge switch to the dining room switch, and the cable from the dining room switch to Satellite 1. So I need to test the cables for all devices in the dining room and then, failing that, it's a physical port on one of my devices rather than the cable.
It could also be a config. issue on one of the devices, or an IP address conflict, etc. But I've checked the IP addresses on the router and I can't see any conflicts.
- FURRYe38Mar 22, 2023Guru - Experienced User
What is the brand and model# of these switches in this segment?
What CAT# lan cable are you using? CAT6 is recommended.
