marcel-s's avatar
marcel-s
No Internet Connection - yet LAN indicates it is connected
Hello,   Just bought and trying to install the RBK23 Orbi mesh router. My setup is: - Fiber internet converter > Vigor2132 modem/router from internet service provider >> RBK23   Inside the Vig...
  • CrimpOn's avatar
    Jun 04, 2020
    Do you have a device that can connect to the Orbi to use the web interface? (not the "app")
    such as a desktop or laptop computer?  I find the web setup more useful.
    p.s. You will discover that having two routers can sometimes cause problems with specific uses.  Netgear describes it this way:
    https://kb.netgear.com/30186/What-is-Double-NAT
    This should in no way interfere with the Orbi router "accessing the internet", but is a subject for discussion in the future.
