Todd_H
Aug 07, 2020Follower
No internet connection after change to Spectrum router
Great experience for almost 2 years with Orbi (+1 satellite) with Spectrum/Time Warner combo modem & router. After ISP-recommended switch to new modem (Docsis 3.1, model EU2251) and separate router (...
Aug 08, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Disable ALL wifi radios on the router, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
2. Or disable all wifi radios on the router and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Todd_H wrote:Great experience for almost 2 years with Orbi (+1 satellite) with Spectrum/Time Warner combo modem & router. After ISP-recommended switch to new modem (Docsis 3.1, model EU2251) and separate router (SAGEMCOM SAC2V2S), no internet connection through Orbi. Tried numerous configurations including connecting Orbi to router, and directly to modem (going through power cycles with each configuration and "New Setup" process in Orbi app with most configurations), but always "no internet connection" through Orbi. Prior to starting updated Orbi to latest firmware (as of 8/7/2020). So Orbi currently deactivated and using WiFi from Spectrum router, but missing out on enhanced WiFi signal from Orbi satellite in back of house. Any assistance would be greatly appreciated.
