PaoloWang
May 30, 2021Aspirant
No Internet connection from one RBS50
Hi guys: Need your help for the RBS50 issue, home network set up by one RBR50 with two RBS50 by the latest firmware. Last week, one RBS50 has the issue which cannot connect the RBR50 with sync fa...
PaoloWang
Jun 01, 2021Aspirant
What Firmware version is currently loaded on the RBR and RBS?
--V2.7.2.104
--- TWO RBS50 sateltes connected with RBR50 by the same configuration go through Netgear GS316 switch.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
--- Using Wired connected between RBR and RBS to set up the home network
Jun 01, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? There shold be a ISP Modem or ONT where you get your serice from or is there just a wall jack?
Is the Orib in router or AP mode?
Is this GS316 switch before the RBR or after the RBR? Has this been factory reset or powered OFF then back ON?
- PaoloWangJun 02, 2021Aspirant
Thanks for the reply, some information I need check when I'm at home.
----The internet Service Provider is China Telecom, neec check the detail when I'm at home.
----AP Mode
------After RBR, I don't try to reset the GS316 due I try to wired the RBR50 and RBS50 directly for the synchronization.
