HRHHD's avatar
HRHHD
Follower
May 08, 2019
No internet Connection when setting up ORBi
I have been having problem getting internet connection when I set up ORBI. It says internet is offline . When I phone virgin media they said it’s the problem with my ORBI NETGEAR . CN anyone recommend to fix the pbe please .
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
  • FURRYe38's avatar
    Any progress on this?
