HARO2021
Dec 09, 2021Aspirant
No internet connection with C6220
Hi all, My ISP (COX) found they can send a signal to my modem, I can reset my modem from COX app, I can connect to my wifi but it just doesn't work, always no internet connection. Anyone has idea...
- Dec 10, 2021
Problem solved. It turns out nothing wrong with my modem and router, maybe cox didn't register my modem in a right way. I called them to reset my modem on their end then problem solved.
Dec 09, 2021Guru - Experienced User
Do you have a screen snip of the cable connections page (shows upstream/downstream connections) and the event logs from the modem?
- HARO2021Dec 09, 2021Aspirant
I'd like to do that. But I just found I'm not able to join the wifi after rebooting for like 2 times. It seems now I have another problem to solve.
I got them.
- plemansDec 10, 2021Guru - Experienced User
Your power levels and logs don't look to bad. I'd find a way to check a hardwired connection to see if its just an issue with wifi.
