ryanjohn04
Dec 25, 2017Guide
No Internet Connection
Anyone ever have this issue? Anything that is always connected to the wifi (i.e. cameras) have no issues. But things that connect and disconnect (i.e. iphone, macbooks) sometimes come up with the *...
DarrenM
Dec 29, 2017Sr. NETGEAR Moderator
In the advanced wireless settings try to uncheck the 20/40 MHz see if this helps with able devices.
DarrenM
- jeffholidayDec 29, 2017Guide
Will give it a try as I just unchecked it now. Will this cause any issues with other devices that I might have connected? Just curious how this might resolve the problem.
- ryanjohn04Jan 07, 2018Guide
Hi Darren- appreciate the followup, but won't this just keep everything at 40Mhz and from what you said we need to force things onto 20Mhz.
