ryanjohn04
Dec 25, 2017Guide
No Internet Connection
Anyone ever have this issue? Anything that is always connected to the wifi (i.e. cameras) have no issues. But things that connect and disconnect (i.e. iphone, macbooks) sometimes come up with the *...
Eric90i
Jan 04, 2018Star
Thanks for the suggestions. Trying out some variations.
One comment though: when I unchecked 20/40mhz coexistence, I scanned my WiFi and found both 2.4ghz bands to be running in 40mhz. I feel that the unchecking of that feature only enables 40mhz. I checked the box again and scanned WiFi, this time it showed 20mhz was active again for 2.4ghz.
guzzijason
Jan 04, 2018Apprentice
Ah, yes... 20/40 coexistence means that it will automatically drop from 40 to 20 if there is interference. If you disable that, it locks it into 40 MHz only it seems.
