ryanjohn04
Dec 25, 2017Guide
No Internet Connection
Anyone ever have this issue? Anything that is always connected to the wifi (i.e. cameras) have no issues. But things that connect and disconnect (i.e. iphone, macbooks) sometimes come up with the *...
guzzijason
Jan 04, 2018Apprentice
DarrenM wrote:Apple devices do not recommend using the 40mhz on the 2.4ghz band since you are having issues with IPads this may help.
For what its worth, that's a general recommendation for any devices using 2.4 GHz in congested areas - not really specific to Apple in any way. It can cause interference problems - it's a problem with the protocol, not with the devices.
Jrsjammin6180
Jan 05, 2018Aspirant
So Darren just to clarify. If the 20/40 box is checked is it running in 20 or 40 or both. Please see Eric90i comment.
Checked or unchecked 20/40 box? Thanks
