ryanjohn04
Dec 26, 2017Guide
No Internet Connection
Anyone ever have this issue? Anything that is always connected to the wifi (i.e. cameras) have no issues. But things that connect and disconnect (i.e. iphone, macbooks) sometimes come up with the *...
Rowie01
Feb 24, 2018Aspirant
Yup - after several days of cameras dropping offline, they’re all working (as is Alexa) but cell phones and iPads get no internet connection. It’s happening right now while i listen to Alexa as I type this. Very frustrated with this system having spent hours resetting etc.
- DarrenMFeb 28, 2018Sr. NETGEAR Moderator
Hello Rowie01
What firmware version are you on? if you are on the 2.1 firmware have you tried to roll back to 2.0.1.4?
DarrenM
- naerokMar 01, 2018Apprentice
this is a known issue documented in this post: https://community.netgear.com/t5/Orbi/What-you-can-expect-with-your-Orbi-system/m-p/1503034#M23257
good luck - so far the only solution seems to be putting a smart outlet / timer on your satellite(s) to reboot them once every 24 hours (I'm not joking) or rolling back the firmware (but I still see people saying they experience the same issues on the older firmware)
- FURRYe38Mar 01, 2018Guru - Experienced User
What the Mfr and model# of the ISP modem that Orbi system is connected too?
Try disbling Beamforming, MIMO and Daisy chaining. Some of said this has helped stablize the system in some cases.
