Zosia
Jan 15, 2023Aspirant
No internet in orbi lbr20 simcard ok
Hi I have problem. It is connected with wifi on orbi but from tomorrow no internet - sim card is OK I checked it several times the provider of internet also. Speed test shows 1mbps/ I rebooted Orbi also... Screen added. What to do more?
1 Reply
- KevinLiTNETGEAR Moderator
Hello Zosia,
Welcome to the NETGEAR Community!
I understand that you are not getting the desired speed readings on your LBR20 network.
Please try removing your Orbi app and then reinstalling it. Then navigate to the speed test tile and administer a speed test.
Please keep us updated on the progress of this issue!
Best,
Kevin
Community Team
