CyclingIPs
Nov 21, 2018Follower
no internet. ISP and modem confirms internet
Orbi has been acting up for a while and now it won’t pass internet through. I’ve tried everything, resetting etc. it says “error not connected” on routerlogin.com. Before this it’s been doing a thing...
st_shaw
Nov 22, 2018Master
If you're having IP conflicts it's not likely Orbi is causing these issues. It's more likely something is not configured correctly or things are not connected correctly. It's impossible to tell for sure without further information about your network, but it sounds like you might have two routers/DHCP servers on your network (Orbi and your ISP modem.)
If you can get on the Internet with your "modem" then it sounds like your modem is also a router. If that's the case, connect the yellow Orbi WAN port to a LAN port on the modem, and setup Orbi to run in access point mode.
- pdawg17Nov 22, 2018GuideIf you have Circle enabled that could do it. For me if I have it enabled, I have tons of DNS timeout errors on wired and wireless devices. As soon as I turn it off everything is good again...
