Mukpat
Sep 04, 2022Aspirant
No internet issues between rbr50 and satalite rbs50 following firmware upgrade v2.7.4.24
Has anyone experienced no internet issues between satalite rbs50 and router rbr50 after firmware upgrade to V2.7.4.24. I have tried resetting satalite and re synch and still drop out happen after sat...
Sep 05, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- MukpatSep 07, 2022Aspirant
Hi
The isp provider is virgin media and I have Orbi router RBR50 connected to Virgin media Super Hub 3. The VM SH3 is in modem mode. The satellite is RBS50 which is part of the RBK50 (router and 1 satellite) system. I have applied FM 2.7.4.24 manually as system not picking it up automatically. Applied FM to satellite first and then to router using the two separate downloads provided by netgear (one for router and another for satellite).
I have also reset configuration settings to factory. I managed to synch the satellite to router when near each other but when moving to another room ie downstairs it seems to lose connection. Checking on the connected devices on router i can see the satellite is there but there is a message auto sync under status. I also tried to sync the satellite to router as i said before managed to get good status but later the status changed to config sync.
The satellite and router were working properly but started seeing issues around the time netgear sent me email alert on the firmware change
I also tested your suggestion on restarting modem, router then satelite this afternoon but issue still there is the status of config sync
