zeehappy
Jul 14, 2019Aspirant
No internet on Orbi Satellite rbs50
Hey all, I’ve been having issues with my Satellite. It connects to my router and says it’s connected but when a device connects to the satellite it’s clear there is no internet connection. Devices ...
Jul 15, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Please power OFF the ISP modem and Orbi RBR for 30 seconds, then power ON the ISP modem and let it sync. Then power ON the Orbi RBR. Walk thru the setup wizard with a web browser.
zeehappy wrote:
Hey all,
I’ve been having issues with my Satellite. It connects to my router and says it’s connected but when a device connects to the satellite it’s clear there is no internet connection. Devices connected to the Orbi router are fine. I’ve factory reset the whole system and nothing has helped. Also an update pops up for the router but the satellite will either fail or endlessly download the update. I hope y’all can help me get this up and running !
zeehappy
Jul 15, 2019Aspirant
Hey!
I currently have V2.3.1.60 loaded on both.
The ISP is Hitron cda3-20.
The NG router is RBR50.
The system is operating in router mode.
Ive tried that but nothing works. :/.
- pablohoneyJul 15, 2019LuminaryI’m noticing this since I updated to the latest firmware version that was released a few days ago. Intermittent connection drops on the satellite.
- zeehappyJul 15, 2019AspirantThe connection is wireless.
- FURRYe38Jul 15, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What does the status say for the RBS50 connected to the RBR?
Is the RBS wireless or wired with the RBR?
Doe any wire connected PC or device get an IP address when connected to the RBS?
- zeehappyJul 15, 2019AspirantIt’s about 2500s sqft, it’s about 30-40 feet away. I’ve never had an issue for a year until now. It says it’s connected and the status is good. The Pc connected to the rbs does get an IP address but the internet is extremely slow/ non existent.
And you did a factory reset on the RBS and re-added it?
What happens if you move the RBS closer to the RBR? Say 20 feet and test at this distance...same thing?
Everything connected to the RBR works ok?
