Pratl
Sep 26, 2019Follower
no internet orbi rbr20
Working with Motorola SB6141 cable modem No WiFi internet I do have internet if I plug directly from Mac to modem Firmware 2.3.5.26 installed on both satellaite and router, in that order manu...
CrimpOn
Sep 26, 2019Guru - Experienced User
On the Home Page where it says the internet connection is Good, under "Wireless" it should have the WiFi name (SSID) and the password should be scrolling across the screen. Maybe it has gone back to the factory default (printed on the bottom label)?
If the "Attached Devices" screen shows only the Mac that is connected to a LAN port, then the router and satellite are not synced.
