toddeberly
May 31, 2018Aspirant
No Internet via WiFi on Orbi RBK33 AC 2200
I have the ORBI RBK33-100NAS AC 2200 model. It's connect to the internet via an Arris SB 6141. There is a persistent problem with the internet connection dropping but only on wifi. The "no internet" ...
toddeberly
I'll answer each in-line:
Any other wifi neighbors near by? if so, how many? - No. I live on a 2 acre lot and and pick up no other signals.
Any other wifi devices near by? - No
What channels are you using? Try manual channel 1, 6 or 11 on 2.4Ghz. Any unused channel on 5Ghz. - 2.4ghz set to Automatic and 5ghz set to 48. I'll try the manual channels and follow-up
Set WPA2 and AES only. - That's what I have set.
Enable Beamforming and disable MIMO, Daisy Chain and Fast Roaming and IPv6. - Had already tried all of that based on a search of the support forum and it made no difference.
What is the distance between the router and satellite? Ft? - 30 ft and the other is about 30 ft from the Satellite when Daisy Chained. When Daisy Chain is disabled each is 30 feet from Orbi. All in open areas w/o obstructions.
Since the FW was probably updated, try a factory reset on the entire system then set up from scratch using the above suggestions.- I found this recommendation on another thread and I tried with all, except for setting manual channel, and it made no difference.
May 31, 2018Guru - Experienced User
I would contact NG support. Might ask for an RMA.
- toddeberlyMay 31, 2018Aspirant
This is my second unit with the same problem. I'm within the window to return it to Amazon as defective, but really hoped I could figure out the problem.
