toddeberly
May 31, 2018Aspirant
No Internet via WiFi on Orbi RBK33 AC 2200
I have the ORBI RBK33-100NAS AC 2200 model. It's connect to the internet via an Arris SB 6141. There is a persistent problem with the internet connection dropping but only on wifi. The "no internet" ...
May 31, 2018Guru - Experienced User
Well, your out in a area with no other wifi sources, all seems to be set up well. You rebooted and factory reset the sysetm. Seems you've tried all you can. I can't think of anythign else that would be causing these problems. Other than a bad batch of product that Amazon might have.
I presume if you set up your old wifi router this works fine? What is the Mfr and model of the old router?
Only thing you might try is a RBK40 or RBR40 series system. I have the CBK40 and it's based on same RBK40 system, just with a cable modem. I find the 40 series very stable.
toddeberly
My old router was a Netgear C7000 and I had not problems. I just needed range extenders. I was looking at the RBK 50 but will consider the RBK 40. Thanks for your suggestions.
