toddeberly
May 31, 2018Aspirant
No Internet via WiFi on Orbi RBK33 AC 2200
I have the ORBI RBK33-100NAS AC 2200 model. It's connect to the internet via an Arris SB 6141. There is a persistent problem with the internet connection dropping but only on wifi. The "no internet" ...
May 31, 2018Guru - Experienced User
If your old router works still, then something is going on with this 33 series system.
Let us know what you go with or end up doing.
- toddeberlyMay 31, 2018Aspirant
I've noticed something odd. If I only use one of the Satellites the internet no longer drops. It doesn't matter which satellite I disconnect and it doesn't matter if I tried them as Daisy Chain or not Daisy Chain. When both satellites are connected the internet periodically drops over wifi and requires a reboot. It's got to be something about the way the units communicate with each other.
- FURRYe38Jun 01, 2018Guru - Experienced User
Ya thats odd. What is the distance between the router and the one satellite?
How big is your home? SqFeet?
I would use only one satellite for now.
