toddeberly
May 31, 2018Aspirant
No Internet via WiFi on Orbi RBK33 AC 2200
I have the ORBI RBK33-100NAS AC 2200 model. It's connect to the internet via an Arris SB 6141. There is a persistent problem with the internet connection dropping but only on wifi. The "no internet" ...
May 31, 2018Guru - Experienced User
If your old router works still, then something is going on with this 33 series system.
Let us know what you go with or end up doing.
toddeberly
I've noticed something odd. If I only use one of the Satellites the internet no longer drops. It doesn't matter which satellite I disconnect and it doesn't matter if I tried them as Daisy Chain or not Daisy Chain. When both satellites are connected the internet periodically drops over wifi and requires a reboot. It's got to be something about the way the units communicate with each other.
- FURRYe38Jun 01, 2018Guru - Experienced User
Ya thats odd. What is the distance between the router and the one satellite?
How big is your home? SqFeet?
I would use only one satellite for now.
