Lavolpe
Dec 01, 2017Aspirant
No internet
Hi,
I recently purchased an orbi system version AC2200 (RBK40) and I have set everything up physically but it road blocks me when it tries to conncec to the internet saying it has no internet connection. I have a Technicolor TC8715D Router/Modem that does give me access to the internet. Enclosed is a file with my ipconfig information. THank you in advance.
If you're plugging a router into a router that's not going to work. You'll either need to set your ISP router in pass-through mode or configure the ORBI system in AP mode which disables the router.
- LavolpeAspirant
Would Bridge mode be the same as pass through mode. Also how may I set it up on AP mode?
Yes Bridge Mode is the same. Set that and you'll be good.
If you want to keep the ISP router/modem as the router and only use ORBI as access points login to orbilogin.com go to advanced, advanced setup, router / ap mode and choose ap mode.
