jallison86
Apr 24, 2018Aspirant
No LED when powering up
Came home today to find no Wi-fi from my Orbi system. The base unit appears inert -- when I cycle power no LED lights come on on the top. The power LED is on, so the unit is receiving power. Tried us...
Apr 24, 2018Guru - Experienced User
How long did you hold in the reset button? Hold it for 15 seconds at least until the top LED comes on Yellowish/Orange color. When you release the reset button, the top LED should start to blink WHITE.
If you don't see any of this, I would contact NG support and ask for an RMA.
- jallison86Apr 24, 2018Aspirant
I've held the reset button for 30+ seconds. I tried holding it down as I cycled power. Nothing. I purchased this unit in April, 2017, just over one year ago. Netgear does not appear to offer any sort of support beyond the $49.99 option. Given the price of the system I certainly hope there is some recourse here beyond simply, "it's dead, throw it away."
- FURRYe38Apr 24, 2018Guru - Experienced User
Might have someone check the power adapter voltage and amps to make sure they are ok. Some adapters can go bad.
You might contact AmitR or DarrenM in a PM and see what options you have...
- jallison86Apr 25, 2018Aspirant
Checking the adapter output is a good idea. I'll give that a shot. Thanks.
- Jeff
