jallison86
Apr 24, 2018Aspirant
No LED when powering up
Came home today to find no Wi-fi from my Orbi system. The base unit appears inert -- when I cycle power no LED lights come on on the top. The power LED is on, so the unit is receiving power. Tried us...
jallison86
I've held the reset button for 30+ seconds. I tried holding it down as I cycled power. Nothing. I purchased this unit in April, 2017, just over one year ago. Netgear does not appear to offer any sort of support beyond the $49.99 option. Given the price of the system I certainly hope there is some recourse here beyond simply, "it's dead, throw it away."
Apr 24, 2018Guru - Experienced User
Might have someone check the power adapter voltage and amps to make sure they are ok. Some adapters can go bad.
You might contact AmitR or DarrenM in a PM and see what options you have...
- jallison86Apr 25, 2018Aspirant
Checking the adapter output is a good idea. I'll give that a shot. Thanks.
- Jeff
