jallison86
Apr 24, 2018Aspirant
No LED when powering up
Came home today to find no Wi-fi from my Orbi system. The base unit appears inert -- when I cycle power no LED lights come on on the top. The power LED is on, so the unit is receiving power. Tried us...
Apr 25, 2018Guru - Experienced User
Hope you can get someting going. Let us know how it turns out.
jallison86
Apr 30, 2018Aspirant
Finally got a chance to check the power supply output. It's right on spec -- 12v @ 3.5A. So unfortunately that's not it. Looks like I'm the owner of two very expensive bricks.
- FURRYe38Apr 30, 2018Guru - Experienced User
I would contact NG support or ChristineT and ask for help and information on this. See if an RMA is available to you. Let us know if you find out anything.
- DarrenMApr 30, 2018Sr. NETGEAR Moderator
Hello jallison86
I have sent you a PM about your unit.
DarrenM
- powdahoundApr 30, 2018Aspirant
I woke up to this exact same issue this morning. Green power LED, no wifi or ethernet activity, and no ring colors on top of the unit. Totally unresponsive to the reset button as well.
DarrenM — Can you help me out as well? Thanks
