4thefamily
Dec 31, 2020Tutor
No lights
Power on, but no Internet and no lights...The WiFi on our Orbi is no longer recognized. Tried to reset, but Orbi is not responding. No top lights. Able to connect to cable WiFi so there is Internet co...
Dec 31, 2020Guru - Experienced User
Try a different power supply? Try one from the RBS to see if any LEDs turn on.
4thefamily
Dec 31, 2020Tutor
Green LED lights up, but nothing else is working. Won’t connect to Internet, won’t reset, no top lights are flashing like during set up.
- FURRYe38Dec 31, 2020Guru - Experienced User
I would make contact with NG support to see what options are available to you.
Good Luck.
