poekie68
Jul 15, 2017Initiate
No more wifi schedule in firmware 1.12.0.18
Hi all, Since the firmware update to 1.12.0.18 the possibility to schedule the wifi signal to turn off is not more available. Previously this could be found in Advanced > Advanced Setup > Wirele...
Jojo666555444
Jul 20, 2017Guide
First off how did you idiots get so off topic. The topic is that they changed the Wi-Fi schedule setting. My comment on this is when I called tech support knowing in India had a clue that they changed it and told me there was something wrong with my update and tried to have me reset the router.
- Supertramp11Oct 05, 2017Luminary
Hi,
I'm facing the same issue with the latest firmware (V2.0.0.74). Did you manage to get the WIFI schedule back under the Advanced Wireless Settings? For me, they disappeared :-(
BTW: Resetting the router to factory settings did not fix this.
- Jojo666555444Oct 05, 2017GuideThey're actually less than helpful. The technical support makes you reset your router settings Wipe Out the entire thing and in the end you have the same exact problem because apparently nobody told technical support that they just got rid of the setting.
That's not good! I can understand that the radios are necessary to keep a connection between the router and the satellite(s). In my family, however, we don't access the network during the night, i.e. I would like to turn them off.
If NETGEAR is reading this thread: please let us know what your plans are bearing in mind that the latest user guide still covers this - for me important - feature.
