poekie68
Jul 15, 2017Initiate
No more wifi schedule in firmware 1.12.0.18
Hi all, Since the firmware update to 1.12.0.18 the possibility to schedule the wifi signal to turn off is not more available. Previously this could be found in Advanced > Advanced Setup > Wirele...
Supertramp11
Oct 05, 2017Luminary
Hi,
I'm facing the same issue with the latest firmware (V2.0.0.74). Did you manage to get the WIFI schedule back under the Advanced Wireless Settings? For me, they disappeared :-(
BTW: Resetting the router to factory settings did not fix this.
Jojo666555444
Oct 05, 2017Guide
They're actually less than helpful. The technical support makes you reset your router settings Wipe Out the entire thing and in the end you have the same exact problem because apparently nobody told technical support that they just got rid of the setting.
- Supertramp11Oct 05, 2017Luminary
That's not good! I can understand that the radios are necessary to keep a connection between the router and the satellite(s). In my family, however, we don't access the network during the night, i.e. I would like to turn them off.
If NETGEAR is reading this thread: please let us know what your plans are bearing in mind that the latest user guide still covers this - for me important - feature.
- DarrenMOct 16, 2017Sr. NETGEAR Moderator
I have escalated that this function is not working properly and our engineers are working on this I will let you know If I hear any updates on the issue.
DarrenM
- Supertramp11Oct 17, 2017Luminary
Thanks Darren. Much appreciated!!
