Argon
Sep 14, 2021Aspirant
No Option to disable 5 ghz under Advanced Wireless Setting
After spending some time trying to connect my TP Link Smart Plug to my new Mesh set up, I googled the issue. Eventually i found where I login to my Orbi network via my mac. I went to the Advanced...
BillYoung
Sep 14, 2021Luminary
As far as I know, there has never been any buttons to disable a channel. You always have both 2.4 and 5 ghz.
