Argon
Sep 14, 2021Aspirant
No Option to disable 5 ghz under Advanced Wireless Setting
After spending some time trying to connect my TP Link Smart Plug to my new Mesh set up, I googled the issue. Eventually i found where I login to my Orbi network via my mac. I went to the Advanced...
Sep 14, 2021Guru - Experienced User
Orbi has never supported disabling of WiFi radios or separation of SSIDs.
One thing you can do is to disable the SSID broadcast temporarily to see if this helps to get the device connected.
Netgear provides a simple mechanism to accomplish this. The Orbi RBR50 has a feature which many users have found allows them to set up devices which require the smartphone to be attached to WiFi at 2.4G:
Connect a device with a large screen to the Orbi web interface, http://orbilogin.net
(computer, laptop, tablet)
The user name is "admin" and the password is the web interface password, not the Orbi 'app' password.
Navigate to the Advanced Tab, Advanced Settings (at the bottom), Wireless Settings.
On the Advanced Wireless Settings page, uncheck the box under Advanced 5G Settings that reads
Enable SSID Broadcast
Click Apply
The router will go through a cycle which takes foreeeeeeeever.
On the smart phone, go into Network settings.
"Forget" the Orbi WiFi.
Search for available WiFi systems.
Select the Orbi WiFi
Enter the password and Connect
The smartphone is now connected to the Orbi at 2.4G
Note that if you attempt to "double check" by opening the Orbi Attached Devices page, that page takes several minutes to update.
Just go with it.
Open the device smartphone app and go through the setup process.
After the device is connected and working, undo the process.
On the web interface, check the box and click Apply
On the smartphone, Forget the Orbi, find it again, and connect again.
This takes less time to do than to read. It has worked for me several times.
Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
One thing to remember, its not up to NG or Orbi to connect 2.4Ghz IoT devices. It's the setup software that these IoT mfrs deploy on the cheap and don't include support in there setup software to include 5Ghz mobile device support since MOST phones and pads are dual band and prefer connecting to 5Ghz rather than 2.4Ghz and these same mfr fail to realized that both 2.4Ghz and 5Ghz are on the SAME side network. Even if there IoT device is only 2.4Ghz, the phone and device can communicate between these frequencies as they are on the same network. Its there setup software that limits the setup phone or pad to be connected to a 2.4Ghz signal when it could be connected to 5Ghz. Something IoT mfrs don't care to fix seems like.
