Argon's avatar
Argon
No Option to disable 5 ghz under Advanced Wireless Setting
After spending some time trying to connect my TP Link Smart Plug to my new Mesh set up, I googled the issue.   Eventually i found where I login to my Orbi network via my mac.   I went to the Advanced...
  • CrimpOn's avatar
    CrimpOn
    Sep 14, 2021
    Argon wrote:
    CrimpOn - when you say use the iphone app - are you referring to the Kasa app for the TP Link Plugs?
    Absolutely.   The smartphone app for TP-Lonk's Internet of Things (IoT) products is KASA.
    I use the Android version (having no fruit devices - pun)
